Node Voltage Problem
Postby tknot2013 » Tue Feb 18, 2014 11:12 pm
Node Voltage.PNG (36.72 KiB) Viewed 100990 times
Im either missing something or have looked at the problem for too long and lost my mind... If anyone can help with the solution to this problem it would be much appreciated! :D
tknot2013
Re: Node Voltage Problem
Postby Ratch » Sat Jan 10, 2015 3:37 am
tknot,
The v2 and v4 node is a natural reference. Why is that same node marked with two different names? Why is the node at the connection of the 3 volt and 5 volts supply set to 0 volts? How do you know that? The 10 ohm resistor in parallel with the 3 volts supply doesn't change any voltages or currents in the circuit. It just puts a load on the 3 volt supply. Remove it and do the calculations.
So, take a cut at solving and post your equations. Solve for nodes v1 and v3.
Ratch
Ratch
Postby PradeepKumar » Wed May 31, 2017 10:41 am
Nodal Voltage Analysis complements the previous mesh analysis in that it is equally powerful and based on the same concepts of matrix analysis.
PradeepKumar
$57.99
Adjustable DC 0-30V/60/120V 0-3/5/10A Lab Power Supply Variable Bench Switching pictureSorensen DCS 150-7 0-150V/0-7A Adjustable High Voltage Power Supply
$250.00
$90.00
EMERSON SOLA SDP 5-5-100T POWER SUPPLY pictureSilent Knight 5495 Power Supply SK-5495 Replacement Board - Used
$329.00
Silent Knight 5495 Power Supply SK-5495 Replacement Board - Used picture
