1N4148 Diode circuit
Postby JasonMcG » Sun Mar 02, 2014 6:02 pm
Design and draw the appropriate circuit to be used in measuring the diode forward current I, using a 5V dc source to forward bias a 1N4148 diode, a 10k ohm potentiometer to vary the dc voltage and a 330 ohm resistor to limit the current through the diode.
Is this the correct circuit? If not, what is the correct circuit?
http://i1362.photobucket.com/albums/r68 ... 8df1b0.png
JasonMcG
Re: 1N4148 Diode circuit
Postby pebe » Mon Mar 03, 2014 10:27 am
As drawn, the voltage applied to the LH side of R1 is fixed. Make it variable by taking R1 to the wiper of the pot instead of to battery+
Postby JasonMcG » Mon Mar 03, 2014 1:41 pm
How do you draw this?
JasonMcG
Postby pebe » Mon Mar 03, 2014 5:19 pm
[quote="JasonMcG"]How do you draw this?[/quote]
I don't understand.
Postby JasonMcG » Mon Mar 03, 2014 5:58 pm
JasonMcG
Postby pebe » Mon Mar 03, 2014 6:43 pm
Yes, thats correct.
Postby JasonMcG » Mon Mar 03, 2014 8:04 pm
JasonMcG
10/2 mc cable 250ft roll of wire green white black new
$330.00
10/2 mc cable 250ft roll of wire green white black new pictureBurndy KS31 DB T1/0-350 70-185 - (Lot of 3)
$99.99
Burndy KS31 DB T1/0-350 70-185 - (Lot of 3) pictureCommon Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned
$230.30
Common Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned pictureCarol Encore Prysmian C1164 Coax, 93 Ohm, 22-SOLID **100 ft.**
$109.74
Carol Encore Prysmian C1164 Coax, 93 Ohm, 22-SOLID  **100 ft.**   picture
