Voltage controlled thru opamp playing up?
Postby diagnostix » Wed Apr 02, 2014 8:39 pm
Hi everyone, we have a project which has the following problem. We are reducing a variable voltage on a cars sensor which ranges from 0-5v. We are using a PIC18 and MCP6004 opamp as a buffer with 56k 33n 56k 4.7n RC filters in and out. The problems we are having are:
1. At around 1.0v - 1.5v we are getting a small surge, and variable voltage which is like a pulsating surge. Beyond this voltage all seems to work fine.
2. At 0.9v instead of reducing the voltage out, what seems to be happening is the voltage in rises instead?
Has anybody an idea as to why this is, and perhaps a solution? We thought maybe it's opamp oscillation, or a feed back issue?
Hope someone can help me.
Mike
diagnostix
Re: Voltage controlled thru opamp playing up?
Postby pebe » Thu Apr 03, 2014 10:43 am
We need more details. Can you supply a circuit of your set-up?
Postby diagnostix » Thu Apr 03, 2014 12:23 pm
Hi, we have removed the PIC today and jumped voltage in - out pins and the opamp circuit works perfect, so maybe the PIC is the problem, we are using PIC18 and pwm at 1250Hz.
diagnostix
$1.80
$9.55
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 picture10PCS Rectifier Diode 6A 10A 1000V DO-27 Electrical Axial Rectifier Diodes
$6.76
10PCS Rectifier Diode 6A 10A 1000V DO-27 Electrical Axial Rectifier Diodes picture4 Terminals Single-Phase Diode Bridge Rectifier MDQ 100A Amp High Power 1600V
$11.95
4 Terminals Single-Phase Diode Bridge Rectifier MDQ 100A Amp High Power 1600V picture
