Circuit Design Assistance needed!
Postby tomaeugen » Thu Aug 14, 2014 7:25 pm
I have the following situation that needs a solution.
I need to come up with a solution to make the following scenarios work:
I have a 12VDC source, one speaker and two switches identified as SW1 and SW2.
The switches are a single pole simple on / off function.
The following is the the intended operational requirement.
When SW1 and SW2 are both Closed (on position), no alarm should come from the speaker.
When SW1 and SW2 are both Open (off position), no alarm should come through the speaker.
When SW1 is closed (on position) and SW2 is Open (off position), no alarm should come from the speaker.
When SW1 is open (off position) and SW2 is closed (on position), Alarm should sound through the speaker.
Can anyone please give ma a hand in designing a small circuit board or any other circuit flow or connection possibilities to achieve the above mentioned required operational scenarios?
Thank you.
tomaeugen
Re: Circuit Design Assistance needed!
Postby pebe » Sat Aug 16, 2014 11:39 am
A 12VDC source will not cause a speaker to make an alarm sound. Is there an oscillator somewhere?
Postby tomaeugen » Sat Aug 16, 2014 11:55 am
Thought about that too, then came up with the idea of using a tone generator
tomaeugen
Postby pebe » Sat Aug 16, 2014 1:55 pm
There is no satisfactory way of solving your requirements by using only those 5 components.
Postby tomaeugen » Sat Aug 16, 2014 2:05 pm
Well... There can be more components, however I need to have only 2 on off switches a tone generator a small speaker and they need to run on 12vdc!
tomaeugen
Postby pebe » Sat Aug 16, 2014 3:01 pm
Is this homework?
If so, what other restrictions are there?
Postby tomaeugen » Sat Aug 16, 2014 3:35 pm
No this is not homework! It's something I'm thinking of building for my home!
There are no restrictions! All it needs to have is as mentioned above and function as described too! So as a bare minimum it has to have the two on off switches, a tone generator, small speaker and it needs to run on 12v. It can have other components to make it work as desired!
tomaeugen
Postby pebe » Sat Aug 16, 2014 3:59 pm
OK. The simplest and most basic method would be use an NPN transistor (Tr1). Let its base be driven by the oscillator via a suitable resistor. Connected its emitter to 0V (negative of the battery). SW1 would be wired from base to emitter of the Tr1.
Connect one side of the speaker to the collector of Tr1. Connect the other side of the speaker SW2. Connect the other side of SW2 to +12VDC.
The only time an alarm would be heard is when SW2 closes to provide power for the speaker, and when SW1 is open, removing the s/c between base and emitter.
Postby tomaeugen » Sat Aug 16, 2014 8:35 pm
thanks for the help. Any transistor will do? or will it need o be a specific one? and the oscillator resistor? One last question, can you please post a simple wiring diagram with the components? so that I can make sure that I connect them all correctly? Thank you again...
tomaeugen
Postby pebe » Sun Aug 17, 2014 2:28 am
What speaker are you going to use?
What is its resistance and max power?
Postby pebe » Mon Aug 18, 2014 2:19 pm
Have you got a particular speaker in mind?
I need to know that to complete the circuit.
Postby tomaeugen » Tue Aug 19, 2014 3:02 pm
No no particular speaker in mind, the smaller the better!
tomaeugen
Postby tomaeugen » Tue Aug 19, 2014 3:20 pm
Is this what you ment?
tomaeugen
Postby pebe » Wed Aug 20, 2014 3:06 pm
I have corrected your circuit. Use a 2N3704 for Tr1 and a 680ohm resistor for R. You have shown no oscillator to generate a tone, so you cannot use a loudspeaker. If you wanted, you could use the two-tone piezo siren shown as item number ST019 on this link, that has its own built-in two-tone oscillator:
http://www.bitsbox.co.uk/index.php?main ... th=302_309
Alternatively, you could use the 2½” 64ohm speaker shown on that page. But that would need a different circuit to include an oscillator (using an LM555). It would also need a series resistor to reduce the voltage applied to it. If you want to go that route, let me know.
temp alarm 2.JPG (27.55 KiB) Viewed 49290 times
Postby tomaeugen » Fri Aug 22, 2014 2:23 am
Thanks for this correction. I will gather the parts and build a small test version early next week. I'm still waiting for the correct pressure switches to arrive.
On a second note... How hard would it be to add a couple more components to this system? For example:
I was thinking of enhancing its design by adding a 10 second sound activation delay after SW1 has opened and SW2 is still closed, and a Bluetooth transmitter, that would connect to a Bluetooth capable phone. On the phone there would be an app (already started working on the app) that would show a message when SW2 is still closed and SW1 is open.
Really appreciate all your help, thanks!
tomaeugen
General Radio Company Co. 1153-AP Digital Frequency Meter Numerik Indicator
$999.99
General Radio Company Co. 1153-AP Digital Frequency Meter Numerik Indicator pictureRadio Frequency Gripmeter Pratt Burnerd Gripmeter 1009-07300 R F Gripmeter
$300.00
Radio Frequency Gripmeter Pratt Burnerd Gripmeter 1009-07300 R F Gripmeter picture5 in 1 Body Sculpting Machine Professional Salon Spa Radio Frequency For Home
$498.00
5 in 1 Body Sculpting Machine Professional Salon Spa Radio Frequency For Home picture0.5M-470M Radio Frequency Signal Source Generator Practical Debugging Instr WRWW
$76.87
0.5M-470M Radio Frequency Signal Source Generator Practical Debugging Instr WRWW picture
