capacitor
capacitor
Postby manish.jadhav » Wed Aug 27, 2014 8:39 am
if i used 1uf 400v capacitor in place of 0.22uf 400v what is the result or should it effect on output tell the diffrence between both capacitor
manish.jadhav
Re: capacitor
Postby KMoffett » Wed Aug 27, 2014 6:44 pm
That depends on the circuit where you change the capacitor's value.
Can you post the circuit?
Re: capacitor
Postby manish.jadhav » Thu Aug 28, 2014 5:40 am
[quote="KMoffett"]That depends on the circuit where you change the capacitor's value.
Ken[/quote]
Tell me one more what is the differance between X rated and y rated capacitor and which one is good
manish.jadhav
Re: capacitor
Postby KMoffett » Thu Aug 28, 2014 2:51 pm
Google: what are X Y capacitors
[url]http://powerblog.vicorpower.com/2013/06/what-are-y-capacitors/[/url]
Re: capacitor
Postby manish.jadhav » Fri Aug 29, 2014 4:45 am
[quote="KMoffett"]Google: what are X Y capacitors
Ken[/quote]
i am not geeting clear idea on tht from this link call suggest some more :idea:
manish.jadhav
Re: capacitor
Postby pebe » Sat Aug 30, 2014 8:52 am
As Ken said, Google for 'x and y capacitors'.
I did and got 420 thousand hits. I am sure at least one of them should be helpful to you.
Johnson Controls MS-CQT485-0 ComBus Quick Tester for JCI N2 Bus
Johnson Controls MS-CQT485-0 ComBus Quick Tester for JCI N2 Bus pictureJOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT
$275.00
JOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT pictureJohnson Controls A70HA-2C A70 Series 4-Wire 2-Circuit Temperature Control
$125.00
Johnson Controls A70HA-2C A70 Series 4-Wire 2-Circuit Temperature Control pictureJohnson Controls Va-7152-1001 Elec Act, 90 In.-Lb., Proportional, 24Vac
$275.00
