Sensor pixel for neural recording
Postby justanengineer » Tue Nov 25, 2014 12:59 pm
I am wondering if instead of using a MicroElectrode Array (MEA) for neural recording, we can use some different circuits like: Voltage to frequency Converter or Digital sensors that are connected directly to the electrode
Ps: the array of electrodes have pitch around 10x10microm^2.
Thanks in advance.
justanengineer
Re: Sensor pixel for neural recording
Postby pebe » Tue Nov 25, 2014 3:51 pm
It would help if we knew why you feel the existing sensors need to be improved, and what sort of device you intend to use to read them.
$27.04
US Stock 154LB 70kg Lifting Magnet Electromagnet Solenoid Lift Holding 59mm 12V picture12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil
$38.44
12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil pictureSDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System
$85.00
$13.63
DC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B picture
