Searching for a special potentiometer.
Postby z26 » Tue Nov 25, 2014 6:17 pm
On the internet, if you search for an arduino compatible joystick, there is a lot of results coming up that look like slight variations of the attached file (the pot's just above the white "27800")
I'd like to get some potentiometers similar to the ones used on these joysticks, since
1. they are pretty small and 2. there is little friction when you are turning the shaft.
However, I wasn't able to find those pots sold separately.
If someone know where to find pots similar to these I'd appreciate the info.
Thanks!
joystick pot.jpg (16.14 KiB) Viewed 29684 times
z26
Re: Searching for a special potentiometer.
Postby KMoffett » Wed Dec 24, 2014 6:19 pm
I Googled: [repair pots for joystick] and under Images found [url]http://www.guitar-parts.com/catalog/korg-pot-joystick-362009052[/url]
Since you didn't say how you wanted to use them, it might be cheaper to just buy a joystick off of eBay and disassemble it.
Quartz See-Through Seahorse Series 510 Connect Coil V5.0 4PCS Box Pack
$24.99
Quartz See-Through Seahorse Series 510 Connect Coil V5.0 4PCS Box Pack pictureBergstrom 500 PSI Condenser Refrigeration A Coil $245 O/B/O
$159.00
Bergstrom 500 PSI Condenser Refrigeration A Coil $245 O/B/O pictureCarrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX*
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureDETYI DG521 Ignition Coil Pack & SP509 Spark Plug Set
$62.99
DETYI DG521 Ignition Coil Pack & SP509 Spark Plug Set picture
