240v relay
240v relay
Postby billl45 » Thu Dec 18, 2014 11:40 am
I need help to time delay the energisation of a 240v ac relay
If anyone can help it would be appreciated
Many thanks billl45
billl45
Re: 240v relay
Postby KMoffett » Fri Dec 19, 2014 7:50 pm
Do you have a link to your 240VAC relay? What time delay do you want?
Re: 240v relay
Postby billl45 » Mon Dec 22, 2014 1:13 pm
Thanks for your reply, the time delay required is 1 second
Could you please clarify what you mean by link.
billl45
Re: 240v relay
Postby KMoffett » Mon Dec 22, 2014 2:18 pm
I was requesting a URL internet link to the manufacturer and specific model of your relay. It helps to know the details of what we are working with. And also, what the relay is switching...voltage and current. It sometimes is cheaper to buy a commercial time delay relay than build something. I hate reinventing the wheel. ;)
$7.77
$400.00
$380.00
Lincoln Variable Voltage PC Board Assembly L5394-2 pictureICM Controls ICM455 Three Phase Line Voltage Monitor Meter Test Device
ICM Controls ICM455 Three Phase Line Voltage Monitor Meter Test Device picture
