Anyone know where I could find this switch?
Postby denno020 » Sun Jan 04, 2015 6:25 am
Hey all,
I've recently bought a new kettle, and I absolutely love the power switch for turning it on.
I've had a look around online but can't seem to find something similar, however I'm searching using some very broad search terms.
I'm hoping that someone would be able to recognise the switch and where I might be able to purchase some, without me having to buy multiple kettles just to take the switch out.
An image is attached showing the switch on the kettle.
Denno
denno020
Re: Anyone know where I could find this switch?
Postby pebe » Sun Jan 04, 2015 7:23 am
Postby denno020 » Sun Jan 04, 2015 9:29 am
Thanks for the reply pebe.
I've manage to find many a rocker switch online, however the main thing about this switch is the white ring around it, which looks to be a part of the switch, and not an addition around a normal rocker switch.
I should have mentioned that in the original post, but thanks for the reply :)
denno020
Postby Scotophor » Mon Feb 23, 2015 12:58 am
Here's one that's somewhat similar, currently offered by at least three sellers on eBay.
Round rocker switch with illuminated blue surround/ring.
Scotophor
Postby PradeepKumar » Thu Aug 24, 2017 7:25 am
Once you can go through with below mentioned link.
www.miracle.net.in/
PradeepKumar
$17.92
$40.50
$225.00
$11.06
