Meditation timer
Meditation timer
Postby geekyworld » Wed Jan 21, 2015 10:51 am
Dear friends,
I'm an electronics newbie. I want to build a meditation timer that would make a sound after a set amount of time, say 45 minutes, has passed. It should be easy to build and should run on 3v or if possible 1.5v .
Can you suggest such a circuit please?
Thanks.
geekyworld
Re: Meditation timer
Postby KMoffett » Wed Jan 21, 2015 7:41 pm
With the cost of ordering parts and the tools to assemble one, I don't think you could come close to the cost of this: [url]http://www.webstaurantstore.com/taylor-5806-classic-digital-timer/913UTL264.html?utm_source=Google&utm_medium=cpc&utm_campaign=GoogleShopping&gclid=CI_qoO7qpcMCFRCEaQodITsAVA[/url]
However, If the building is the most important part, for circuits Google: CD4060 long timer
Postby geekyworld » Thu Jan 22, 2015 2:39 pm
Thanks a lot for your answer Ken. I've been thinking along the same lines.
geekyworld
Postby PradeepKumar » Tue Sep 06, 2016 5:31 am
Taylor 5827-21 White Classic Digital Timer is one of the best mediation timers to go about with.
PradeepKumar
$173.56
$49.99
Used - RV 30A 50A Amp Inverter Generator Parallel Companion Kit  125V 30 50 AMP pictureHoymiles HM-300N Grid Support Utility Interactive Inverter Microinverter
$39.97
