555 timers
555 timers
Postby kraverauk » Sun Feb 22, 2015 9:13 pm
Hello, I am an electronics student at college and i am creating an alarm system for my car. I want the alarm to run for 10 minutes but i am unsure how to create a 555 timer circuit that makes the alarm run for 10 minutes? I have created a few test circuits using the 555 timer with a battery, two resistors, a capacitor and an LED to get the LED to run for a certain amount of time but i can only to get it to blink and not stay on for a set amount of time, can someone please give me advice ?
kraverauk
Re: 555 timers
Postby KMoffett » Tue Feb 24, 2015 1:58 am
You could try this monostable 555 circuit: [url]http://www.technologystudent.com/elec1/5554.htm[/url]. C1=470uF and R2=1MΩ will give you ~517 seconds. Use a CMOS 555.
$17.92
$40.50
$225.00
$11.06
