Would like to convert a DPDT switch...help!
Postby swedespeed7 » Fri Apr 03, 2015 6:59 am
Hi guys,
I'm kind of poking around in the dark here, but hopefully someone can help me out. Here's the deal:
I have a DPDT rocker momentary switch that controls a 12V motor. Press and hold the switch one direction, the motor opens a door until it's all the way open. Vice versa, door closes until all the way closed. Opening/closing takes about 3 seconds.
If the switch is kept depressed in either direction, the motor will continue to receive power and would most likely burn out eventually.
[b]My goal is to convert the momentary rocker switch to a single push-button switch. For example, the switch is pushed and the motor operates until the door is all the way open. Press it again, motor closes the door all the way.[/b]
I'd like to accomplish this without having to modify the motor or door.
Is there a way to use relays to accomplish this? Something else? I'm somewhat familiar with the standard 5-pin relay but that's it.
If this is possible, what type of switch should I use?
Thank you in advance!
swedespeed7
Re: Would like to convert a DPDT switch...help!
Postby KMoffett » Fri Apr 03, 2015 2:15 pm
Automatic timing to control the opening and closing of the door is not reliable, as in holding the rocker switch too long. The easiest method is to add a controller with limit switches to detect the open and closed positions. However, that means mechanically modifying the door/frame/latch...something. Another less invasive way is to monitor the door motor's current for a stall condition at full ope=n and full closed.
Postby swedespeed7 » Fri Apr 03, 2015 3:42 pm
[quote]Another less invasive way is to monitor the door motor's current for a stall condition at full ope=n and full closed.[/quote]
That's exactly what I'd like to do. How can I accomplish this?
swedespeed7
Postby KMoffett » Fri Apr 03, 2015 5:27 pm
Can you post a schematic of what you have now?
Postby swedespeed7 » Fri Apr 03, 2015 6:31 pm
You know what, don't worry about it. I think I may have found a solution. Thanks!
swedespeed7
Postby KMoffett » Fri Apr 03, 2015 11:54 pm
Care to share?
$27.00
$469.95
$299.99
