Cisco Catalyst 3560 Series
Postby justina17 » Thu Apr 09, 2015 8:17 am
Is there a limit to the number of SFPs that can be used on a Cisco Catalyst 3560 Series Switch?
justina17
Re: Cisco Catalyst 3560 Series
Postby pebe » Thu Apr 09, 2015 12:09 pm
The best people to know would be Cisco.
Go to their website and use 'Contact Us' to get the answers.
Postby kellysue » Fri May 15, 2015 4:14 am
No. Users can populate all the SFP ports of any [url=http://www.3anetwork.com/cisco-catalyst-3560-series-switches-price_c40]Cisco Catalyst 3560 Series Switch[/url] with the same SFP or with a combination of different SFPs.
kellysue
$27.04
$13.63
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves
$375.99
