5v 200ma trigger need to power 12V buzzer
Postby johnmikebolognone » Thu Jun 11, 2015 8:26 pm
I have a temperature sensor that when the temperature is out of range, it will set a pin to +5v. I need to take that trigger and drive a 12Vbuzzer. Can someone help me design a simple way of using that trigger to drive the buzzer?
I was thinking to use an optocoupler to seperate the 5v side from the 12v of the circuit, but don't think i can run the higher amperage through the optocoupler.
I am a newbie, so speak slow... :)
johnmikebolognone
Re: 5v 200ma trigger need to power 12V buzzer
Postby KMoffett » Fri Jun 12, 2015 8:16 pm
This should serve your purpose, if the 5V and 12V supplies can share a common (-) ground. The Q1 MOSFET can be almost any one that can handle a 200mA current. The Diode D1 is not critical either.
Postby johnmikebolognone » Tue Jun 23, 2015 12:56 pm
That works perfectly. Thanks!
johnmikebolognone
$17.92
$40.50
$225.00
$9.83
