Need help converting servo audio amp
Postby costanza » Tue Jun 16, 2015 9:10 pm
https://goo.gl/photos/E5tGzMipSx2rQuBv7
Press the [u](V)[/u] downward pointing arrow on the page to view full resolution.
I'm trying to convert an old Velodyne F-1200 servo feedback amplifier to work with non servo woofers. If I unplug the accelerator feedback plug from the factory driver and leave positive and negative audio leads attached, the woofer starts making ticking noises. I've read that clipping a single capacitor lead may stop the amplifier from requiring this feedback to work correctly with regular non-servo woofers. Thanks!!
costanza
$149.00
$565.00
$799.99
$198.95
