dc-cdi 12/220 issue
dc-cdi 12/220 issue
Postby oldsnake » Sun Aug 16, 2015 1:01 am
I want to build a dc-cdi by the circuit as shown.I have a problem: If install 1 transistor(tip122) output voltage equal to 220 vac if install 2 transistors(tip122) an output voltage equal to 158 vac.Why is this?
What do I need to use two transistor voltage = 200 vac.?
Thank.
oldsnake
Re: dc-cdi 12/220 issue
Postby KMoffett » Sun Aug 16, 2015 7:24 pm
Do you mean if you use just Q1, you get 220VAC out. If you use just Q2 you get 220VAC out. But if you use Q1 and Q2 you only get 158VAC out. Have you looked at the transistors' collectors and the transformer's output with an O-scope?
Postby oldsnake » Mon Aug 17, 2015 8:24 am
ken Yes I mean your post. I start in electronic no have O-scope. Can I simulate in proteus and use O-scope in program?
oldsnake
Postby KMoffett » Mon Aug 17, 2015 1:26 pm
Sorry, I don't use simulators, but I would hope that Proteus has an o-scope function that could help you trouble shoot your circuit. If you post the simulator file, maybe others that use and have a lot of experience with that program could see what's happening.
Postby oldsnake » Tue Aug 18, 2015 12:45 am
This is simulate file.Help me please.
TEST.rar
(23.52 KiB) Downloaded 881 times
oldsnake
$16.98
Lot of 2 - Littelfuse TECCOR - S4055M - SCR. 55Amp 400V, TO-218.  Thyristor New picture5000A Phase Control Capsule Thyristor Convex Type SCR Silicon Controlled Ballast
$185.00
5000A Phase Control Capsule Thyristor Convex Type SCR Silicon Controlled Ballast pictureSCR Thyristor SKN6000/04 for Semikron VF1.20V 14KA
$118.84
SCR Thyristor SKN6000/04 for Semikron VF1.20V 14KA picturePower Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82
$54.99
