help with PWM and volt/amp meter
Re: help with PWM and volt/amp meter
Postby KMoffett » Wed Oct 14, 2015 1:34 am
Placing a pot in series with the buck converter's output is not the way, as you have found, to control the voltage to the motor. You need to replace the pot in the buck converter with an equivalent external pot,
Postby Macman » Thu Oct 15, 2015 1:58 am
Ok Ken I ordered a new buck converter because the one I had even the mounted POT was not changing the volt output so I figured I start with a new one. the problem is going to be getting an external POT for it. only electric store here is Fry's not sure they have many to choose from
Macman
Postby KMoffett » Thu Oct 15, 2015 11:01 am
Can you you post a link to your new buck regulator?
Postby Macman » Thu Oct 15, 2015 5:56 pm
http://www.ebay.com/itm/301484905256?_t ... EBIDX%3AIT
I got this one because these motors can pull some amps and I wanted to be safe
Macman
Postby KMoffett » Thu Oct 15, 2015 11:14 pm
It looks like that also has an on-board trim pot to adjust the voltage. So you would have to remove it and run wires to an external pot.
Postby Macman » Fri Oct 16, 2015 12:25 am
right but do you think this 2000 ohm POT I have p/n RV4NAYSD202A will work?
Macman
Postby KMoffett » Fri Oct 16, 2015 12:56 am
I can't read the values of the trim pots in the photos, so I can't say.
Postby pebe » Fri Oct 16, 2015 3:15 pm
With an on-screen magnifier I can just make out '103' on the LH pot and '?03' on the RH one. That accords with the buck converters I have used.
Check that yours are, if fact, marked 103. If so they are 10k linear pots
Postby Macman » Thu Oct 22, 2015 11:10 pm
ok I got the buck converter now which POT is the volt output and what external POT should I get to replace it
Macman
Postby KMoffett » Fri Oct 23, 2015 12:07 am
On your web link, they indicated the there was adjustments for voltage and current limit. Is there an instruction sheet that indicates which of the trim pot is used for voltage adjustment? Is there any printing on the PCB that indicates voltage adjustment?
Postby Macman » Fri Oct 23, 2015 2:27 am
yea on bottom of circuit board under each pot. one says V-adj and one is I-adj. so guess V-adj is volts
Macman
Postby KMoffett » Fri Oct 23, 2015 10:53 am
Do you have the equipment and skill to carefully un-solder and remove the V-adj trimmer pot? You would then solder in three wires into the empty holes, to connect to your external 10K pot. Wire in center hole goes to the pot's center (wiper) lug. The other two wires go to the pot's outer lugs. The convention is that clockwise rotation increases the voltage. If you find that counterclockwise increases voltage, swap the wires to the outed lugs.
Postby Macman » Fri Oct 23, 2015 5:35 pm
I can solder and I have a solder remover (wouldn't let me use the word that I really call it.. sounds like pucker but with an S..LOL) I guess I can use to help remove the pot but reality is I have never removed an item from a circuit board before. what would happen if I just soldered the external pot to the solder spots on bottom of board and left the original pot on the board?
Macman
Postby KMoffett » Fri Oct 23, 2015 5:49 pm
That wouldn't work. You can't parallel the pots in this case. I might suggest you find some old PCB's from consumer electronics devices (TVs, stereos, radios) and practice on those. Your regulator is probably not a high quality PCB, so it might be easy to overheat a trace during desoldering and lift it off the board.
Postby Macman » Fri Oct 23, 2015 6:13 pm
OK now im worried because these buck converters take so long to get I don't want to mess it up. my solder iron is set at 800 should I lower it so I don't over heat the board. on my way right now to get a 10k pot then we will see what happens
Macman
PreviousNext
DHG 12oz Crystal Clear PET Plastic Cups 98mm Lid Case of 1000
$144.59
DHG 12oz Crystal Clear PET Plastic Cups 98mm Lid Case of 1000 pictureDental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA
$145.00
Dental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA pictureInternet AI —TI84 Plus Calculator with ChatGPT, Gemini, Claude
$239.99
Internet AI —TI84 Plus Calculator with ChatGPT, Gemini, Claude pictureScintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM
$49.00
Scintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM picture
