Help identify circuit.
Postby huntered56 » Sun Aug 09, 2015 2:26 pm
Can anyone please tell me what the circuit is in the picture. It is the brownish one with the cm221-2550 printed on it. I need to fine one to replace one of them on the main board for a pellet stove. Thank You
huntered56
Re: Help identify circuit.
Postby KMoffett » Sun Aug 09, 2015 7:43 pm
The label on the PCB looks like is F26(?). The labels on the other three similar ones are F22 and ????. Usually "Fxxx" is for fuses. With three pins it might be a hybrid filter module. Is that the one you want to replace... or is it similar to one on another PCB. If you don't know what it is, how do you know it needs replacing? What make and model stove control?
Postby huntered56 » Sun Aug 09, 2015 8:43 pm
it is the brownish one this is from a dell europa pellet stove
huntered56
Postby huntered56 » Sun Aug 09, 2015 8:50 pm
Here is a pic. with the one I am looking for circled in white
pellet stove 1.JPG (406.8 KiB) Viewed 15674 times
huntered56
Postby KMoffett » Mon Aug 10, 2015 1:34 am
Likely a custom part. You might want to contact the manufacturer of the stove. Dell-Point Technologies is now Paromax.
[url]http://www.paromax.ca/dir/index.php?option=com_content&view=article&id=51&Itemid=8&lang=en[/url]
But likely they will only sell a new PCB.
Postby bwetman » Fri Oct 23, 2015 10:24 am
"I don't know exactly , is this winrich pellet stove ? & in this heat sensors are used? If any one is know about it please tell me"
bwetman
$49.99
JOHNSON CONTROLS VALVE ACTUATOR  ‎3Nm (27in-lb)  /  VA9203-GGA-2Z pictureJOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT
$275.00
JOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT pictureJohnson Controls A70HA-2C A70 Series 4-Wire 2-Circuit Temperature Control
$125.00
Johnson Controls A70HA-2C A70 Series 4-Wire 2-Circuit Temperature Control pictureJohnson Controls Va-7152-1001 Elec Act, 90 In.-Lb., Proportional, 24Vac
$275.00
