help with PWM and volt/amp meter
Re: help with PWM and volt/amp meter
Postby KMoffett » Fri Oct 23, 2015 6:55 pm
Way lower. Not sure what will work best. That's why I suggested practicing it on scrap PCB.
Postby pebe » Fri Oct 23, 2015 7:27 pm
I have removed about half a dozen of these pots from converters, so I can give you a run-down on the best method, if you want.
Postby Macman » Fri Oct 23, 2015 8:48 pm
ok great all help is welcome
Macman
Postby Macman » Fri Oct 23, 2015 10:34 pm
does it have to be a special pot. I used a 10k pot and the input volts read 11.60 but output now is 2.75 to 1.50 as I turn the pot
Macman
Postby pebe » Sat Oct 24, 2015 3:40 am
How did you get those results if you haven't got the old pot out?
Postby Macman » Sat Oct 24, 2015 11:50 am
I got the old pot out and wired in the new one
buck (640x480).jpg (148.14 KiB) Viewed 28652 times
Macman
Postby pebe » Sun Oct 25, 2015 11:28 am
The pot needs to be a linear type - nothing special. Your problem is almost certainly be one of these:
1. Have you got the leads to the pot in the correct order? - your centre(white) lead should go to the centre of the three on the pot.
2. Is the current-adjust pot limiting the available current? Try turning the current pot clockwise.
3. Have you damaged the copper connections on the PCB? Check with a magnifier.
Postby Macman » Mon Oct 26, 2015 5:43 am
seems that its working ok now. I think it was that the motor was bad and was not drawing the volts but I hooked it all up tried a car with a good motor and all is working. just a few cosmetic things to fix tomorrow and I will post a video of the whole thing working. thanks Ken and pebe for you help and patients.
Macman
Postby Macman » Tue Oct 27, 2015 1:49 am
well I said I would post what I made when I finished it so you guys that helped could see what you helped with. I build the box from scratch and its used to carry slot car racing equipment to the track. on top is where all the electrical headaches came from. there are still something's I don't like that im going to work on like how the POT sticks up to high and I think some felt or rubber on the test cell might make it quieter. any way thanks for all the help and advice.
[url]https://youtu.be/1KzSIc1W_lQ[/url]
Macman
Postby Macman » Wed Oct 28, 2015 9:34 pm
question...why when I put on a car with a motor that has not been tested on the box it starts by going up to almost 12 volts but as I turn down the volts with the pot it will then only go back up to 8 volts then 6 volts. when I remove the car and there is no load on it the meter goes back up to 12 volts. but put the car back on and it still will not reach 12 volts
Macman
Postby KMoffett » Thu Oct 29, 2015 2:06 pm
If the current on you meter plateaus as the voltage drops, it sounds like your regulator is going into current limiting. That's adjusted with the other trim pot. Otherwise, if the supply voltage drops below the regulators input limit for 12V than the power supply has insufficient capacity.
Previous
$12.62
Analog Panel AMP Current Ammeter Meter Gauge DH-670 0-50A DC & Shunt pictureGENUINE MURPHY AMMETER AMP GAUGE 60-0-60 65700259 HOTROD DUNE BUGGY
$45.00
GENUINE MURPHY AMMETER AMP GAUGE 60-0-60 65700259 HOTROD DUNE BUGGY pictureFCI DC Amperes Analog Panel Meter Ammeter Gauge Model/MPN D.C. AMPERES
$16.99
$79.00
Lot of 8 Analog Panel Meters Yokogawa Jewell MeterMaster Voltmeter Ammeter picture
