Find the voltage gain of the classical difference amplifier
Postby lgrada14 » Mon Nov 16, 2015 11:44 pm
Find the voltage gain of the classical difference amplifier for the case R1 = R3 = 10 kΩ and R2 = R4 =
100 kΩ. What is the differential input resistance Rid? If the two key resistance ratios and are different from
each other by 1%, what do you expect the common-mode gain Acm to be? Also, find the CMRR in this case.
(a) Neglect the effect of the ratio mismatch on the value of Ad and (b) do not neglect the mismatch.
lgrada14
Re: Find the voltage gain of the classical difference amplif
Postby pebe » Tue Nov 17, 2015 4:03 am
Is this homework?
$6.48
10PCS Rotary potentiometer linear 15MM 1K 2K 5K 10K 20K 50K 100K 250K 500K 1M pictureAllen Bradley 800T-U29 Potentiometer 800TU29 Series Q
$170.00
Allen Bradley 800T-U29 Potentiometer 800TU29 Series Q picture5 Set linear Potentiometer Kit 15mm 3Pin B1K 2K 5K 10K 20K 50K 100K 250K 500K 1M
$6.47
5 Set linear Potentiometer Kit 15mm 3Pin B1K 2K 5K 10K 20K 50K 100K 250K 500K 1M pictureAllen Bradley 800T-U41 30.5mm Potentiometer Unit, 50 Kilohms Resistive Element
Allen Bradley 800T-U41  30.5mm Potentiometer Unit, 50 Kilohms Resistive Element picture
