Controlling Voltage and Current
Postby Plmrguest » Fri Nov 20, 2015 4:31 am
I am trying to control voltage range from 1.5 to 34 V using LM338 voltage regulator with 1000u capacitor at the input 430u capacitor ; at the output with potentiometer @ the adjustment terminal.
I have 37v and around 5 Amps current at the Vout but when i try to reduce the voltage using potentiometer,resistor 120 ohms burns out. Please suggest me how to control and get constant Voltage & Current.
Plmrguest
Re: Controlling Voltage and Current
Postby Relayer » Sat Nov 21, 2015 11:31 am
[quote]Please suggest me how to control and get constant Voltage & Current.[/quote]
[b]Hello Plmrguest,
Can you please put up a picture of [u]YOUR[/u] schematic and how you wired it up.
Relayer[/b]
Relayer
Postby bwetman » Thu Dec 24, 2015 5:07 am
Hello,
Using voltage regulating device like (BJT & FET) we can control the voltage and current.
bwetman
Postby pebe » Thu Dec 24, 2015 12:47 pm
[quote="Plmrguest"]I am trying to control voltage range from 1.5 to 34 V using LM338 voltage regulator with 1000u capacitor at the input 430u capacitor ; at the output with potentiometer @ the adjustment terminal.
I have 37v and around 5 Amps current at the Vout but when i try to reduce the voltage using potentiometer,resistor 120 ohms burns out. Please suggest me how to control and get constant Voltage & Current.[/quote]
Forget the LM338 series regulator. What you need is a switched mode buck converter like this one. It's easier to use and much more efficient.
http://www.ebay.co.uk/itm/DC-Buck-Step- ... XQ3kNTgqYl
$1.80
$18.99
AVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style pictureRectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10
$32.62
Rectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10 picture5Pcs 1000V 50A Metal Case Single Phase Diode Bridge Rectifier KBPC5010 5X
$9.89
5Pcs 1000V 50A Metal Case Single Phase Diode Bridge Rectifier KBPC5010 5X picture
