need direction
need direction
Postby smcauley » Tue Dec 08, 2015 6:13 pm
I have a specific need for an electronics project
I have done minimal circuit work in the past and believe what I am looking for should be simple and inexpensive to produce
I want to play an MP3 audio clip (10 seconds or so) when lamp is turned on
I currently have an IR remote that energizes a lamp, when the lamp is lit I want to hear the Audio file,
What I am envisioning is some type of "box" that will sense when the line is energized
and play the MP3 file,
so the input would be 110v or, a signal from a current sensor contact
and the output would be a phono plug or headphone jack that I could send to an amp/speakers
smcauley
Re: need direction
Postby rouncer » Tue Dec 08, 2015 8:54 pm
make the sensor be the volume knob on the amplifier.
rouncer
Re: need direction
Postby KMoffett » Wed Dec 09, 2015 7:25 pm
Something like this with an LRD(light dependent resistor/photocell)+transistor to trigger the PCB.
[url]https://www.sparkfun.com/products/11029[/url]
Re: need direction
Postby bwetman » Mon Dec 21, 2015 6:12 am
Hello,
Have you used any kind of software in it ?
bwetman
Re: need direction
Postby PradeepKumar » Thu Aug 11, 2016 5:39 am
The idea is good. You could make use of a sensor for it.
PradeepKumar
Re: need direction
Postby Relayer » Fri Aug 12, 2016 12:25 am
[quote="PradeepKumar"]The idea is good. You could make use of a sensor for it.[/quote]
Once again you revive a thread that the OP will never answer.
Relayer
6 units Lenovo SR665 Server 8x NVME 2x1100W ,2x AMD 7V13 CPU , 1TB 2933MHz RAM
$134644.20
6 units Lenovo SR665 Server 8x NVME 2x1100W ,2x AMD 7V13 CPU , 1TB 2933MHz RAM pictureSCHNEIDER ELECTRIC PAS600PWD PoE ECOSTRUXURE PANEL SERVER GATEWAY
$400.00
$600.00
$35.00
