yx802 ic
yx802 ic
Postby tassyted » Thu Jan 14, 2016 1:21 am
I cannot find any info on YX802 IC which is the ic in a solar gutter light and also what would be an alternative part...Cheers and any help would be very welcome . PS .This is my first post
tassyted
Re: yx802 ic
Postby KMoffett » Thu Jan 14, 2016 5:24 pm
[url]http://www.datasheet-pdf.com/PDF/YX802-Datasheet-HuajingElectronics-912095[/url]
[url]http://www.aliexpress.com/store/product/free-shipping-10pcs-YX802-DIP-8-LED-solar-lawn-lamp-driver-IC-YX802-IC-DIP-8/425586_32242282300.html[/url]
Re: yx802 ic
Postby tassyted » Fri Jan 15, 2016 5:16 am
Thanks a lot Ken..Nothing on an alternate part? Cheers and thanks again
tassyted
Re: yx802 ic
Postby KMoffett » Sat Jan 16, 2016 1:13 pm
Go to Google Images and search for: solar garden light IC
There appear to be a lot of different ones. There are links from the images to web pages with more information or vendors. If you can get the YX802, why do you want an alternative IC?
Re: yx802 ic
Postby PradeepKumar » Fri Jun 03, 2016 9:14 am
There are so many online stores such as ishopsnet, pelens and aliexpress who sell this product.Try checking them out.
PradeepKumar
$5.99
$6.47
5 Set linear Potentiometer Kit 15mm 3Pin B1K 2K 5K 10K 20K 50K 100K 250K 500K 1M picturePotentiometer 250ohm Ohmite CLU-2511 -Type A/B - 2 Watt
$14.50
Potentiometer 250ohm Ohmite CLU-2511 -Type A/B - 2  Watt pictureCavitron power potentiometer for Gen 131, 132, 136, 137
$125.00
Cavitron power potentiometer for Gen 131, 132, 136, 137 picture
