RF COMMUNICATION OF MESSAGE WITH MICROCONTROLLER
Postby ORGENES » Sat Feb 06, 2016 9:30 pm
Hi...
I have a project to design and implement a circuit which will send message encrypted in micro controller through RF technology from RF transmitter to the RF receiver separated at a distance of about 100M. Now i want to use RF modules operating at 433MHz and two micro controller. The problem here is a circuit which will take signal from micro controller to transmit to the receiver and what values of components such as(resistors and capacitor ) will be used to stabilize circuit.
Any one have more idea about that circuit diagram, please help me even a link to follow.
Thanks.
ORGENES
Re: RF COMMUNICATION OF MESSAGE WITH MICROCONTROLLER
Postby pebe » Sun Feb 07, 2016 5:10 pm
Have you decided on which RF modules you will be using? Many have simple logical high/low inputs and outputs that can interface with the micros directly.
All you then need is micro software that can send/read the data.
Postby ORGENES » Sun Feb 07, 2016 6:40 pm
Thanks...
I decide to use TX 433MHz as transmitter and RX 433MHz as receiver. These have no pins digital pins hence i decide to use RF Decoder and RF Encoder, before micro software to read data, how will a circuit be?.
ORGENES
Postby pebe » Mon Feb 08, 2016 8:53 am
This pair of modules has data pins for normal 0-5V logic.
Use 5V for the Rx and up to 12V for the TX to get the range you require.
http://www.ebay.co.uk/itm/433Mhz-RF-tra ... Sw2s1UrXSE
It needs only simple sub-routines to send and receive serial data, a byte at a time, from a micro; each byte with a start and a stop bit (10bits).
$13.49
$130.00
Salisbury 21405WT16 Dielectric Overboot 20 KV Size 16 17 Inch Tall, Deep Heel pictureRFS Manual Grounding Jacket Striping TOOL RFS-916423 RFS 916423 JSTRIP-114
$249.99
RFS Manual Grounding Jacket Striping TOOL RFS-916423 RFS 916423 JSTRIP-114 pictureLineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read Lot L
$54.95
Lineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read  Lot L picture
