Draw schematic for old school power supply
Postby Circ de Uits » Wed Feb 10, 2016 4:09 am
What started as an effort to restore an outdated (1972) automobile distributor tester, has developed into a desire to understand the electronics of the power supply module. I have photos and a crude sketch of the elements of the module. My goal is to develop a proper schematic drawing of the circuit(s) and understand the function of each of the elements. The main function of the power supply is to drive a rotating plate that contains a flash tube, and to trigger the flash tube for stop action effect. Conductivity through the rotating shaft is by graphite brushes and copper contacts. I would also like to learn which components (if any) may be replaceable with modern equivalents.
Is this a proper topic for this forum? If so, I can scan the sketch for posting and start the dialog.
Circ de Uits
Re: Draw schematic for old school power supply
Postby pebe » Thu Feb 11, 2016 1:46 pm
OK. Let's have more details.
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureRectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10
$32.62
Rectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10 picture20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set
$17.99
20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set picture4-Channel MOSFET Driver Board 5-24V DC Switch Module Arduino ESP32 | KI Maker
$19.95
4-Channel MOSFET Driver Board 5-24V DC Switch Module Arduino ESP32 | KI Maker picture
