Emulating a throttle
Postby A_edwill » Mon Feb 22, 2016 5:14 am
Looking for a circuit for linear voltage isolation. I am running 0 - 4.7vdc output from an Arduino board via a DAC. Output must be linearly transferred to a motor controller which has its own 5vdc supply and ground. http://www.monsterscooterparts.com/24v- ... oller.html. Basically I am trying to imitate a throttle. Tried an H11F1 circuit, was able to create an isolated linear voltage circuit but it fails when hooking up to the 3 wire throttle sensor wires on the controller. :?
A_edwill
Re: Emulating a throttle
Postby pebe » Tue Feb 23, 2016 5:59 pm
I don't know what you mean by 'linear voltage isolation'. The output from your DAC is an analogue voltage. You can only isolate (from DC) an AC waveform, so what exactly is the type of voltage you wish to transfer? Or are you intending to use a pulse of variable amplitude and want a circuit for it?
100 COMMERCIAL CRYSTAL 10 LB LBS 1.5 MIL Plastic Ice Bag Bags With Drawstring
$20.50
100 COMMERCIAL CRYSTAL 10 LB LBS 1.5 MIL Plastic Ice Bag Bags With Drawstring pictureBorescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera
$29.99
Borescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera pictureInternet AI —TI84 Plus Calculator with ChatGPT, Gemini, Claude
$239.99
Internet AI —TI84 Plus Calculator with ChatGPT, Gemini, Claude pictureScintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM
$49.00
Scintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM picture
