Help to design circuit
Re: Help to design circuit
Postby DillBoothe » Wed May 18, 2016 6:51 pm
Hi...i read your post and want to know if you have the Dim on and the Bright off, do you want them both to come on when the Main Lights are shut off and turned on again?Once you hit the Dim button, the Dim stays on and the bright goes off, do you want the Bright to come back on if you hit the Dim button again? Like toggling between Dim and Bright+Dim while the Main Lights are on?
Advert deleted by moderator
DillBoothe
Postby PradeepKumar » Wed Jun 21, 2017 10:43 am
Thanks for sharing good information.
PradeepKumar
Previous
Quartz See-Through Seahorse Series 510 Connect Coil V5.0 4PCS Box Pack
$24.99
Quartz See-Through Seahorse Series 510 Connect Coil V5.0 4PCS Box Pack pictureBergstrom 500 PSI Condenser Refrigeration A Coil $245 O/B/O
$159.00
Bergstrom 500 PSI Condenser Refrigeration A Coil $245 O/B/O pictureCarrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX*
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$39.73
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW picture
