Square wave signal with ADC converter
Postby tnnelectronics » Thu Mar 01, 2018 11:51 am
I have a 7Hz 5Vpp square wave signal, you give me an advice on an easy way, to turn that signal into the corresponding DC voltage, so I can read it through the microprocessor's ADC converter?
Thank you.
tnnelectronics
Re: Square wave signal with ADC converter
Postby KMoffett » Wed Mar 07, 2018 2:32 am
Do you want to just detect the presence or absence of this signal? Or a voltage corresponding to frequency, peak pulse voltage, or mark-space ratio?
National Semiconductor LM3909N Lot of 8 8-Pin TH Flashing LED IC
$25.00
National Semiconductor LM3909N Lot of 8 8-Pin TH Flashing LED IC pictureDCA55 Version Semiconductor Tester, Compatible with DCA55 Semiconductor Analyzer
$88.88
$180.00
Semiconductor Equipm. 24339-9.00 Dicing Tape, Clear, UV Curable, 9-inch, 3.3 mil picturePrinted Circuit Board Magazines
$100.00
Printed Circuit Board Magazines picture
