Square wave signal with ADC converter
Postby tnnelectronics » Thu Mar 01, 2018 11:51 am
I have a 7Hz 5Vpp square wave signal, you give me an advice on an easy way, to turn that signal into the corresponding DC voltage, so I can read it through the microprocessor's ADC converter?
Thank you.
tnnelectronics
Re: Square wave signal with ADC converter
Postby KMoffett » Wed Mar 07, 2018 2:32 am
Do you want to just detect the presence or absence of this signal? Or a voltage corresponding to frequency, peak pulse voltage, or mark-space ratio?
$149.00
$565.00
$799.99
$198.95
