Square wave signal with ADC converter
Postby tnnelectronics » Thu Mar 01, 2018 11:51 am
I have a 7Hz 5Vpp square wave signal, you give me an advice on an easy way, to turn that signal into the corresponding DC voltage, so I can read it through the microprocessor's ADC converter?
Thank you.
tnnelectronics
Re: Square wave signal with ADC converter
Postby KMoffett » Wed Mar 07, 2018 2:32 am
Do you want to just detect the presence or absence of this signal? Or a voltage corresponding to frequency, peak pulse voltage, or mark-space ratio?
$5.99
$6.47
5 Set linear Potentiometer Kit 15mm 3Pin B1K 2K 5K 10K 20K 50K 100K 250K 500K 1M pictureClarostat RA20LASD103A 10K OHM Wirewound 10000 Ohm Potentiometer Industrial POT
$16.90
Clarostat RA20LASD103A 10K OHM Wirewound 10000 Ohm Potentiometer Industrial POT pictureCavitron power potentiometer for Gen 131, 132, 136, 137
$125.00
Cavitron power potentiometer for Gen 131, 132, 136, 137 picture
