Total noob wanting to undertake custom laser tag project
Postby PsychoThruster » Fri Oct 14, 2011 6:23 pm
Okay, so I have a pretty ambitious vision for a laser tag system and would like to know what material I need to read/watch in order to learn the skills required to approach this project. It will use basic laser tag IR sender/receiver to shoot and and register hits. I would like to add a few neat twists however, such as using a removable and rechargeable battery that will double as an ammunition clip. As in reloading requires swapping out for a new battery. Say 50 shots per battery. I also want to run LEDs and speakers for effects. An ammunition display would be nice too. I realize this probably branches into several different areas of expertise, and this does not concern me as I am prepared to dedicate the time required to learn. I simply need pointing in the right direction. So if any of you could recommend some good books or videos on the subject for a total beginner, I would greatly appreciate it. Thank you.
PsychoThruster
Postby newtonph » Tue Oct 25, 2011 1:01 pm
That's revolutionary for laser tagging game and technology. That's too advance for me, good luck on looking..
newtonph
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureRectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10
$32.62
Rectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10 picture20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set
$17.99
20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set picture4-Channel MOSFET Driver Board 5-24V DC Switch Module Arduino ESP32 | KI Maker
$19.95
4-Channel MOSFET Driver Board 5-24V DC Switch Module Arduino ESP32 | KI Maker picture
