CRT monitor no display
Postby elmer1007 » Tue Mar 01, 2011 3:49 am
I've been using my CRT monitor for 1 year and it didn't have any short circuits or whatever. When I turn on the PC, I hear somethings that is like scratching or zapping sound. Then "poof" no more display. I heard the sound under the screen but I didn't smell a burned circuit. Anyone know about this case? :?:
elmer1007
Postby madhuGanesh » Tue Mar 15, 2011 9:50 am
Check for power supply. If it is functioning good you have no other option than to take it to the service provider
madhuGanesh
Postby smithhooper » Tue Apr 05, 2011 7:15 am
I had the data from my old HDD copied to the new one, and it worked then, on an LCD monitor.When boot process is done, move your mouse for about 30/60 seconds rapidly on your mouse pad.No signal, gives a strong message that your monitor is working good, but the signal from the CPU is not good most time.
smithhooper
$1.80
$9.55
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 picture1N5408 Diode 1000V 3A [ for Rectifier, TTL, Arduino, Pi Projects ]
$11.18
1N5408 Diode 1000V 3A [ for Rectifier, TTL, Arduino, Pi Projects ]  picture4-Channel MOSFET Driver Board 5-24V DC Switch Module Arduino ESP32 | KI Maker
$19.95
4-Channel MOSFET Driver Board 5-24V DC Switch Module Arduino ESP32 | KI Maker picture
