Adapting RF transmitter to headphone audio input
Postby eswick » Fri Jun 28, 2013 3:11 am
Hi all. I am currently trying to create an FM transmitter on a breadboard for a project. I am currently using the circuit here: [url]http://www.circuitstoday.com/long-range-fm-transmitter-1[/url].
I have a few questions about this circuit. Firstly, the circuit is set up for a piezoelectric microphone. As I have absolutely no idea where to obtain one of these cheaply (maybe I just haven't looked hard enough?), I would like to adapt this circuit to transmit audio from a headphone jack, preferably the audio output from an iPhone. I am not experienced enough to figure this out on my own, although I have gone through many pages and articles on the internet. The output voltage/amperage from the headphone jack doesn't appear to be quite standard. Also, I'm not sure if the output from the headphone jack is in the same format as the piezoelectric microphone. If anyone could help me out with adapting this circuit for headphone output, it would be [i]extremely[/i] appreciated.
As for my second question; in R1, there are 3 outputs for a resistor. Is that a special resistor? I believe I am missing something.
I would be very grateful for any help on these questions. Thanks!
eswick
Re: Adapting RF transmitter to headphone audio input
Postby electroyas » Mon Jul 01, 2013 7:34 pm
As i can understand you are tryiing to send the iphone audio output through headphone jack without any sound comming out. So why do you need a mic? You can send the audio signal comming from the device to the transmitter through some small capacitor for ac coupling only. Safer for the iphone.
Life is a great mystery
electroyas
Leeds & Northrup Co 8248-12 Rotary Selector Switch 12-Position with Wiring
$149.99
Leeds & Northrup Co 8248-12 Rotary Selector Switch 12-Position with Wiring pictureEZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA
$29.00
Sensor Switch NPP20 PL  nLight Plenum Plug-Load Control 120V, 20A picture200 Amp Transfer Switch, 48000W General-Duty Double-Throw Safety Switch
$104.99
200 Amp Transfer Switch, 48000W General-Duty Double-Throw Safety Switch picture
