Need help simplifying circuit
Postby geryuuu » Tue Feb 25, 2014 3:50 am
need help figuring out how to simplify
Need help figuring out a more simplified version.Im just having trouble figuring out whats parallel and in series
geryuuu
Re: Need help simplifying circuit
Postby geryuuu » Tue Feb 25, 2014 5:25 pm
I can figure most of it out, I just don't know how to write down R5, I believe it is parallel to both R6 and R4. Not 100% though
geryuuu
Postby pebe » Wed Feb 26, 2014 1:48 pm
If you want to simplify between two nodes, where are they?
Postby geryuuu » Fri Feb 28, 2014 5:51 pm
between a node centered between (r5 and r6) and (r5 and r4).
geryuuu
Postby pebe » Sat Mar 01, 2014 5:25 pm
Are not those points on the same top line?
Variscite VAR-SOM-MX7-5G MX7 Console Motherboard + White Housing 1500mAh USB
$30.00
Variscite VAR-SOM-MX7-5G MX7 Console Motherboard + White Housing 1500mAh USB pictureEBR874198 PCB Motherboard Control Display Panel Button Board For LG EBR87419861
$84.43
EBR874198 PCB Motherboard Control Display Panel Button Board For LG EBR87419861 pictureTCN2010 Vending Machine Main Control Board PCB Nuvoton NUC972
$115.00
TCN2010 Vending Machine Main Control Board PCB Nuvoton NUC972 pictureNEW OLD STOCK FIC 1ST MAINBOARD MOTHERBOARD VA-503+
$249.99
NEW OLD STOCK FIC 1ST MAINBOARD  MOTHERBOARD VA-503+ picture
