Help with a Dayton DC Speed Control
Postby Tillman33 » Tue Jul 01, 2014 12:21 pm
I have a Dayton DC Speed Control where the potentiometer is not working. It's almost like it's not there. The voltage is at 106 vdc no matter if the pot is fully opened or closed. The pot is good. Has anybody had any experience working on these and know what it may be. Thanks.
Tillman33
Users browsing this forum: Majestic-12 [Bot] and 0 guests
Wall Switch, Gray, 1/2 HP, 1-Pole Switch
$17.90
Wall Switch, Gray, 1/2 HP, 1-Pole Switch pictureEZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA
EZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA pictureSquare D Air Compressor Pressure Switch 135-175 PSI Pumptrol Grey Manual
$119.99
Square D Air Compressor Pressure Switch 135-175 PSI Pumptrol Grey Manual pictureSensor Switch NPP20 PL nLight Plenum Plug-Load Control 120V, 20A
$29.00
Sensor Switch NPP20 PL  nLight Plenum Plug-Load Control 120V, 20A picture
