Current Driven LED Circuit
Postby Veys » Fri Jul 25, 2014 2:54 pm
Hello All,
I am currently designing [b]an LED array[/b]. It consists of 20 LEDs which will light up one at a time in sequence. The first design looked something like this with the switch array representing logic 0 outputs on micro-controller:
Buffer Resistor Design
IR On.png (151.7 KiB) Viewed 13266 times
I need to ensure that the intensities are controlled however using a constant current method. I have decided upon this design which uses a shunt regulator to maintain required current through LED:
Shunt Regulator Design
TLV431 Single IR LED ON.png (81.85 KiB) Viewed 13266 times
The problem I am having is that I cannot come up with a suitable way of replicating this design x20 times over, short of just using x20 of each components. Any ideas? MUX's are expensive no?
VEYS
Veys
Re: Current Driven LED Circuit
Postby pebe » Sat Jul 26, 2014 7:18 am
Why do you need a constant current controller?
I assume you are using a stab 5V source, in which case your simple resistor feed, R1, should be OK.
Postby Veys » Sat Jul 26, 2014 11:24 pm
LED intensities depend on current flow through them. The application requires the LEDs to operate at known wavelengths and so the typical buffer resistor design is not adequate.
Veys
Postby pebe » Sun Jul 27, 2014 8:54 am
The wavelength of a LED is determined during manufacture and stays the same whatever current is used to drive it. I have driven an IR LEDs with pulses of 4us at a current at over 1A to get a range of 30ft, and the wavelength did not change. I would be interested to know your application.
If your application is very fussy on drive current I can give you a simple constant current circuit to replace R1 in your first circuit.
Postby Veys » Sun Jul 27, 2014 9:23 am
It is the intensity that varies not the wavelength. I ensure uniform
brightness is controlled via current input.
Veys
Postby pebe » Sun Jul 27, 2014 9:45 am
[quote="Veys"]The application requires the LEDs to operate at known wavelengths and so the typical buffer resistor design is not adequate.[/quote]
I assumed that you thought the wavelength changed.
[quote]I ensure uniform brightness is controlled via current input.[/quote]
In your top circuit, R1 is common to all LEDs, so they should be equally bright.
However, do you want the circuit?
Postby Veys » Sun Jul 27, 2014 10:09 am
Apologies the wording was ambiguous. The purpose is to emit pre-defined wavelengths at equal intensities. Thus if the current isn't controlled I will have no control over the intensity emited. Any circuit revisions are welcome. :)
Veys
Postby pebe » Sun Jul 27, 2014 11:15 am
This constant current circuit can replace R1 in your top circuit.
Constant Current 2.GIF (2.86 KiB) Viewed 13208 times
$169.75
Southwire 28828255 250 ft. 12/2 Solid Romex SIMpull CU NM-B W/G Conductor Cable pictureCommon Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned
$230.30
Common Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned pictureCommon Sense Marine 18 Gauge 2 Conductor Marine Wire 75 ft 18/2 AWG
$61.24
Common Sense Marine 18 Gauge 2 Conductor Marine Wire 75 ft 18/2 AWG pictureEaton Crouse-Hinds C67 Type C Conduit Body 2in Form 7 Feraloy Iron Alloy
$339.99
Eaton Crouse-Hinds C67 Type C Conduit Body 2in Form 7 Feraloy Iron Alloy picture
