I am currently designing [b]an LED array[/b]. It consists of 20 LEDs which will light up one at a time in sequence. The first design looked something like this with the switch array representing logic 0 outputs on micro-controller:
- Buffer Resistor Design
- IR On.png (151.7 KiB) Viewed 13270 times
I need to ensure that the intensities are controlled however using a constant current method. I have decided upon this design which uses a shunt regulator to maintain required current through LED:
- Shunt Regulator Design
- TLV431 Single IR LED ON.png (81.85 KiB) Viewed 13270 times
The problem I am having is that I cannot come up with a suitable way of replicating this design x20 times over, short of just using x20 of each components. Any ideas? MUX's are expensive no?
VEYS
